vs ii gearbox or other issue
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Garth, Feb 9, 2008.
  1. Garth
    Garth Your guess is as good as mine...... Staff Member
    100 series Toyota Landcruiser V8 monster
    ok, so this is hte drama
    have a person i know with a vs s2 auto wagon. idle the car up, it idles quite nicely, put it in gear, it goes into gear, put foot down, it dies. we changed gearbox (dont ask they told me box was shaged) yet issue still persits, it honestly feels like it's stumbling to breath or not getting enough fuel when acelerator is applied
    ideas?
  2. immortality
    Sth Auck, NZ
    checked for error codes? could be MAF
  3. Garth
    just read codes before got the following
    12 No RPM Signal OK stationary engine
    22 TPS Voltage Low -auto trans code
    23 IAT Voltage High
    32 MAF Out of Range
    35 Idle Speed Error
    58 Transmission Fluid Temp. -auto trans code
    Voltage Low
    66 3-2 Shift Control Solenoid Circuit Fault -auto trans code
    67 TCC ON-OFF Solenoid Control Circuit -auto trans code
    69 TCC Stuck ON -auto trans code
    81 2-3 shift Control Solenoid Circuit Fault -auto trans code
    82 1-2 Shift Control Solenoid Circuit Fault -auto trans code
    83 Torque Converter Clutch PWM Circuit -auto trans code
    it pretty much spat every single transmistion code out at us. upon investigation it would apear that the plug for the gearbox might not be in the right spot. we are unable to get to the plug properly so we might have to drop the arse of the box down adn do it that way. would this explain the codes? or is the car about to blow up?
  4. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    sounds silly garth but check the fuses... you are nissing a main power supply somewhere
  5. Garth
    found the problem.
    when they put the gearbox back together they failed to plug in the sensors and stuff that are located inside the box. idiots. every single plug is un-pluged, lucky for us we kept the old box, pluged it all in, and bingo, it works.
