VS indicators not working
Bethws76
47
Maryborough Qld
VS Berlina HSV V8
Hi all. New here. I have a 1996 VS V8 Berlina. Hazard lights working, blinkers working on lock and unlock, checked all fuses - all ok. Replaced indicator stalk and flasher relay - no change. Can’t see BCM under dash but lots of covers. Any ideas on where to go from here please? Everything else works only the indicators not working.
wamboin23
Donating Member w/ Boost
34
Wamboin, NSW
VS Calais - Cooled L67 + T56 | VF SSV Ute
Possibly a faulty hazard switch.
Click it a few times, and make sure it coming back out all the way.
If you have the means of doing so, check you have an ignition feed to the flasher unit while the ignition is on. If not, its a good bet the hazard switch is faulty.
Bethws76
47
Maryborough Qld
VS Berlina HSV V8
Thank you. Had tried pressing the hazard switch but didn’t fix it. I am getting the hazard switch replaced on Monday. Fingers crossed that is it. Cheers
