69HKPREMIER
- Jan 15, 2011
- 22
- 0
- 0
- Age
- 40
- Location
- Melbourne
- 1969 HK Holden Premier, 1998 VS S S3 Ute
G'day,
My wifes VS is having an intermittent starting issue and im going bonkers trying to figure out.
20 percent of the time it just won't start, heres what happens:
Put the key in, turn it, you hear a click and the warning light comes on ( ! )
Wait a few minutes try again and it starts first crank.
Other times you jump in turn the key and it starts first crank, no problem.
it is not the nuteral switch, as it has been pulled out and cleaned, also if the car is not in park or neutral the ( ! ) does not come on when you attempt to start the car.
Have poured water over CAS, as suggested elsewhere in forum, did not help.
Error Code is 12
I'm not sure where to go from here... any ideas?
Error Code is 12
