peteinoz
- Nov 29, 2020
- 338
- 443
- 63
- Age
- 60
- Location
- gold coast
- vs commodore ute
So I just bought a very tidy 98 VS L67 ute
As it turns out my 17 year old daughter is extremely keen to go drag racing.. Bonus!!
I did my time as an apprentice mechanic and did 2 years after that, but haven't really touched the spanners much since then, erhm 3 decades ago.
So this will be fun, lots to remember and learn.
this is the parts list, main reason I bought it.
The l67 engine has
1.9.1 high ratio roller rockers.
Hsv xu6 enhanced l67 chip
85mm pullie
Reco snout
New charger oil
Low compression pistons
New 82 degree thermostat
New temp sensors
New altonator
New vacuum lines
New plugs gaped at .9mm
New high performance coil packs
New msd high performance leads
New radiator hoses
New coolent
New heater tap valve
New homoinick balancer
New exhaust manifold gaskets
GSS 342 walbro high flow fuel pump
New speed sensor
New crank angle sensor
New o2 sensors
New neutral sensor
Hi Teck extractors into a Custom made 2 1/2' exhaut with high flow cat into twin 3" tip sounds really tough
New pod filter
New shifter cable
B&m shifter set up over $450
New Saas racing seats (mod plated)
adjustable panhard rod
Super low king springs
Super low monro shocks
Super low struts
New bushers
New tie rod ends
New brake pads
Strut brace
rubber mat in the tub made of tires looks really nice
Led Parker's
New clear tail lights
New clear custom blinkers
Boost & vacuum gauge
New fire extinguisher
Custom red & black interior
New pioneer head deck Bluetooth etc
New 2 500watt 6" by 9" speakers in a custom built boxes behind the drivers and passenger's head
Drift steering wheel
New crash pad
Custom roof lining black with the Holden lion done in red
Custom red n black door cards
Mod plated
Down the highway it's under 2k revs sitting on 100k's so I'm guessing it's got a 3.08 open diff in it.
One thing you don't see here, is currently, the passenger footwell is completely filled with this massive speaker.
If you don't know, behind the cab in the ute, front part of the tray has a removable section.
If you take that off, you'll see the petrol tank behind the drivers and a big open space behind the passenger seat
which also has large vents into the cab.
Some genius makes these, that fit a 12 inch sub in them.
So that was the first order, from Ebay
LOL to get rid of that massive thing in the passenger well.
My daughter has spent 2 solid days cleaning and detailing it.
Oh and thanks to @
Phillbert
I ordered this little gem from ebay also
First test.
Leave it exactly as it is and see what times my daughter and I can pull out of it.
I'm not expecting that much, maybe in the 15's possible high 14's?
Then the idea is to do 1 improvement each time between races
First thing is to get it to hook up, since I'll be using it a little bit to drive around, probably go the 3.7 ratio instead of the 4.11
most likely just get what the best deal is, with a minispool most likely.
then see the difference.
Then slicks.
You guys would know better than me.. I've got 15 rims to put the slicks on.. would 255's be the widest you can go on one of these?
Well that's my start of the tread, I'll be updating it as we add new things to it.
So I've got a complete record of it from scratch etc.
We are going to name it and put this car on Instagram as another record etc.
All and any advice appreciated along the way, it's been a while
Pete
The l67 engine has
85mm pullie
Reco snout
New charger oil
New temp sensors
New altonator
New vacuum lines
New radiator hoses
New coolent
New speed sensor
New o2 sensors
New neutral sensor
New pod filter
New shifter cable
Super low struts
New bushers
New tie rod ends
New brake pads
Strut brace
Led Parker's
New crash pad
Mod plated
Oh and thanks to @
Phillbert
First test.
Then slicks.
Pete
