H
harrop.senator
Guest
Yeah man so you've got 100% argon , 2% oxygen , Argo shield , tri mix etc.
Has to match the work your predominantly doing.
If you plan on doing mainly stainless buy stainless gas and filler rod or wire. It can be used on mild steel and the weld won't corrode.
You can weld stainless with mild filler or wire to but then you've got weld corrosion issue possibilities.
Same for alli.
Same for alli.
