Just after some clarification guys. Looking at putting a VT/VX/Vy v6 into my VS. i dont need the management from the same car to run it do i? if i use all the sensors, plugs ins etc from my motor it would work right? Im just not 100% sure thats all
I'm pretty sure the computer is quite different in later models to compensate the little changes / upgrades done to the engine. Not sure, but I believe that you'll benefit greatly with the more recent computer system in these later models. Vx onwards have 152Kw and vt pretty much same as the Vs with 147kw.
i belive VX has better engine management and some changes to the intake manifold to give it extra power also the vy has a larger sump
What i want to know tho, guys, is that will the VT/VX/VY motor "plug in" and run using the ecu, sensors and bolt ons off my current motor? surely it would right? since its the same motor, except has a better 'brain'
I'd say yes it will work, my mate has a vs calais and recently installed the engine from a written off VX commy. he said there were problems but got it to work.
