what did you go with in the end?
No worries mate, makes sense. Just keep the thing properly maintained, regular gas system servicing and engine tuning, and you will be more than happy. Most of the problems that people whine about even with older gas systems are caused by lack of maintenance. Poor tuning is exaggerated by a mixer system, but stick it in for a regular checkup and it will serve you well. It will save you a heap of moolah.
That's exactly what I was told by the dudes. They basically said, keep your ignition system upto spec take the system in for a check up every year and you'll set provided you don't go hooning in it.Do your normal services as usual and replace the air filter twice a year
Do keep around 1/4 tank of petrol in the tank because to low a fuel will stuff up the fuel pumps.
No need to start on petrol at all although some systems do automaticly.
Drive until you run out of gas then change over to petrol.
My 94 VR has 422,000 on the clock atm and in the 4 odd years i've owned it still gets 450ks to 65litres :w00t:
You do need to start on petrol for the mixer setup unless you want to sit there for s couple minutes while it struggles to fire up.
Sent from my GT-I9100 using Tapatalk 2
