VS Manual computer into auto
Wayne Gregory
55
brisbane
vb
What happens if you accidently put a manual computer into an auto. Mine ran for about 20 seconds roughly I turned it off as I noticed had wrong computer in. Swapped with auto, now has spark but wont run. What damage have I done? Any help would be appreciated.
Immortality
Staff member
Sth Auck, NZ
I don't think it should cause any issues. There are slight differences in the tune and on the board for the different transmission speed sensor but otherwise auto and manual are identical.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
If you haven't disconnected the battery to clear any logged codes, then try the disconnect. Then try to restart it.
Wayne Gregory
55
brisbane
vb
thanks guys ill keep looking sounds like timing as it kicks back while cranking possibly cam or
crank sensor
gtrboyy
vt ss & lc gtr
Thought vats would prevent it from starting
woteva
NEED 4 SPEED
Adelaide S.A.
Not in a VS. The ecu doesn't care what BCM it has connected as long as it gets the correct signal.
Grimes
NSW
VS Commodore Series II Ute
crank sensor
A kick back will happen if you have a pair of plug leads crossed over. If you had them unplugged check them again.
losh1971
North Tas
VE Series I SS Ute
Messing with the PCM can make VATS kick in, it happened to me. It normally occurs if the battery or engine fuse is not disconnected when swapping memcals and or PCM's.
gtrboyy
vt ss & lc gtr
Hmm maybe I put vr 185i memcal in vs 304 to see if it would run or go better compared to stock 165 memcal but instead got anti-theft signal/fault....was 20yrs ago
Although read somewhere vats somehow different from vr to vs or it's in tune *shrugs*
