VS Manual Wiring
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VSEXEC, Apr 28, 2011.
  1. VSEXEC
    VSEXEC Member
    VS EXECUTIVE
    Hi guys, i just want to know if the VR method of wiring up the speed sensor for an auto to manual conversion can be used on VS V6 ecotec if so where do you need to splice into the signal wire from the computer. Is it behind the dash cluster or right at the computer. Thanks
  2. Clint_G
    Clint_G Member
    05 VZ SS
    Im pretty sure the wiring for the gearbox is the same for both vr and vs so it should be fine. And you could hook up the speedo both ways just depends on how you wanna do it
  3. VSEXEC
    VSEXEC Member
    VS EXECUTIVE
    ok ill give it a shot last time i tried it spliced right at the ecu and the car just stalled
  4. Clint_G
    Clint_G Member
    05 VZ SS
    Make sure you join the right ones. I think there are two that look the same at the ecu. And if you cut the wrong one the car wont drive properly.
  5. VSEXEC
    VSEXEC Member
    VS EXECUTIVE
    thanks see how i go tomorrow
