family fix it man
- Aug 31, 2012
- 47
- 2
- 8
- Location
- Australia
- VS Executive wagon, VE wagon
Hi I'm a bit stuck with this problem.
I have a bad miss-fire at about 2000 to 2600 RPM. Worse when hot. Probably needs a top end job, (slight oil in coolant, oil clean) but I can't afford that at the moment.
Worse under load, seems to go away over 3000 RPM, but I don't want to have to rev that much.
Manual V6, new fuel pump, new injectors, throttle body cleaned. (Fuel return line in tank has no clamp, as I couldn't get the fitting off to replace that one)
Coils seem OK.
I am thinking plugs or fuel, or CAS, or temp sensor, air sensor, but it runs fine at idle (bit of high idle though, then settles).
Also starts missing after cornering, which I think points to fuel?
Fuel filter done a few 100k ago, but I suspect it might have picked up some dirt from the pump change.
No error codes. (was thinking of getting ALDL cable, but no codes with old paper clip)
Coils seem OK.
