VS motor in Vt - can't start car
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by beezawoman, Jan 27, 2012.
  1. beezawoman
    beezawoman New Member
    Devonport TAS
    VT Commodore Series 1
    Hi, we have dropped a vs motor into a vt commodore series 1. Can turn car over but cannot get it to start. Please help! Have replaced crank angle sensor. Taken to mechanics - says voltages check out ok. Getting desperate to get this car going now
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    You need to link the BCM and ECU with a TECH 2. It's a security thing.
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    If the BCM and ECU are still the originals, it shouldn't be a security issue, you need to change a couple of sensors over too, the engines are basically the same, just the VT uses a few different sensors. Put the VT sensors on the VS motor.
  4. beezawoman
    Devonport TAS
    Hi. The BCM and ECU are still original. We have replace crank angle sensor. Please advise which sensors need replacing please.
  5. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    I know the coolant temp sensor is in the VS but not in the VT, so the plug for it shouldn't be there. Don't attach anything to the VS sensor.
  6. loopie
    loopie Member
    sa
    vx
    surely the mechanic should have sorted it out.
  7. luckyvt94
    luckyvt94 Member
    Hobart Tasmania
    vz Thunder SS
    I know this is an old thead but can anyone tell me which sensors are different? Any help will be helpful
  8. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    The VS ecotec uses 2 seperate temp sensors on the front of the inlet manifold, ones for the temp gauge (single wire) and ones for the ECU (multi wire). The VT and later ecotecs use just the 1 single temp sensor for both ECU and temp gauge. The VS ecotec doesnt have EGR either, so you just need to swap over the inlet and exhaust manifolds from the VT engine to the VS engine, this solves the EGR and the temp sensor problems..
  9. luckyvt94
    luckyvt94 Member
    Hobart Tasmania
    vz Thunder SS
    Oh ok so easy fix then
