edwardos11
- Aug 10, 2008
- 8
- 0
- 0
- Location
- mt gambier, aus
- Website
- www.myspace.com
- vs acclaim series 2
this morning i went to start my car. put the key in, turned to on position, all warning lights turned on (oil, engine, all the usual stuff) and tried to start the car via push buton switch i installed (never had any problems with it). as soon as i depressed the button, everything cut out. nothing was working at all. putting the key in and out, turning on acc and on had no affect, its like the main fuse had blown and cut everything out.
i checked all my fuses, none blown. checked engine relays, no problem. poked around with wiring in the bengine bay, no visible signs of a fault.
it seems like it cuts out for a period of time because after a length of time, everything operates as per usual, warning lights on when key is in on position, but as soon as i press the start button the same happens. everything cuts out and absolutely nothing works.
also, when everything operating normally, i can hear a high pitched ringing coming from the bay. i dunno if thats normal, but never noticed it b4.
help greatly appreciated. i cant live with out driving my car one day='(
cheers(Y)
cheers(Y)
