VS on Gas
THZ-NSC
STRETCH
Warwick
VR SS, VB SLE, VR STATESMAN
hi all, jzt bought a vs and its dual fuel, doesnt really run on gas well, but runs like new on fuel. I went to get roady n waz told i need gas certificate,#1 where or how do i get 1??? #2 Does running ur v6 on gas do damage to engine #3 or should i just pull gas out??? Dnt know wot 2do neva had a car on gaz b4
fireballv8
59
canberra
Vs 2 aclaim wagon, Vs 1 belina wagon, VS1 calais
Holden did sell some VS's new with gas, is it a aftermarket fitting, or genuine? Any autogas fitter can test the gas system for rego. "Commodores DO NOT like gas"???, I want to put gas on my VS wagon, i have had gas powered cars before, and it saves so much on fuel cost. If Holden did it factory, the cars must be able to run on it with out problems ??
oztatts
gold coast
vq statesman
id take it to a gas specialist and get a full service. i had a commo on gas and it run like a bag a sh**...
383 hatch
39
Cowes, Phillip Island
#1: Ask the person doing the roadworthy exactly what needs to be done, if it just needs the tank re-tested (should be done every 10 years) then you can get mobile guys to do that on site (you need to remove the tank first)
#2: Yes.
#3: Yes.
It's pretty well known that Commodore V6's don't really like gas (gasfitters will tell you different as they want sales :p). Anyone who thinks LPG saves you money in the long run is deluded.
Cheap6
VP Exec
If it is a straight roadworthy certificate you will only need to find a workshop licenced to work on LPG systems. Phone book? It will cost a bit more than a standard certificate but not much.
Potentially, running on LPG can be hard on valves both the seats and the guides. It's a temperature issue so worst at sustained high speed and load. Using a memcal (and wiring it in to the fuel changeover switch) from the factory approved system will add some petrol while running on LPG at high loads for cooling. There is no need to be concerned if you don't have it with a car of the age of a VS - it takes a lot of km's for any damage to occur, especially if you're not planning any high speed runs through NT - the rest of the car will probably fall apart first.
The LPG memcal also has a seperate ignition map for when running on LPG. This also minimises the valve wear (retarded ignition timing causes hotter exhaust valves).
It helps to run on petrol occasionally; something like half a tank a month. That also avoids any problem with petrol deteriorating from being left in the tank for an extended period of time.
An engine on any fuel running at less than optimum tune will wear faster. Given the nature of LPG fuel systems it is more likely that they will be running at less than optimum tune but there isn't anything inherent with LPG that means it has to be less than optimum.
There can be a greater tendency for acid build up in the oil - also a temperature issue - and higher running temperatures tend to lower oil viscosity under the conditions which the engine is actually running. There are oils specifically designed to cope with those issues but using an oil with a viscosity range on the higher end of those recommended and changing it at shorter intervals is an alternative.
The spark plugs should be changed and the leads checked every 20K km - LPG is more sensitive to ignition problems.
It helps to have a cooling system that is in good condition.
If the engine does die, replacements aren't hard to find and should be under $1K fitted.
Nope. That will cost you money (or at least time) to do and your fuel bills will double. A typical Commodore might use ~$2400 per year of petrol - 20K km, 10l/100km, $1.20/l (you can do your own maths for your car and its use - factor in +30% consumption on LPG). Including the cost of using a small amount of petrol, $1200 buys a lot of repairs on LPG even if they were to be needed.
Burnout124
Western Australia
VY Executive S2/ VY SS 6sp
My vy 6 is on gas not a problem i have also had a vp on gas it had done 400,000km on gas it ran fine just keep the gas tuned and you wont have a prob any gas fitter can service and tune your system.
rb26dett
46
VT SS S2 A4
Personally if it were me, I would be running it on straight gas and not duel fuel.
Cheap6
VP Exec
It makes no difference. If you were to make mechanical changes that optimised the engine for operation on LPG, sure but that costs $$. Where you are running a standard engine (optimised for petrol) and you can switch ignition maps optimised for each fuel there's not much point in running straight LPG, especially since you lose the benefit of petrol assisted start, high load cooling and the extra range available using both fuels.
It would remove the extra maintenance involved with having duplicate fuel systems but against that is the reliability of having redundancy in the fuel systems; (almost) the only thing that will stop a dual fuel Commodore running is an ignition fault, everything else can be worked around roadside at worst.
