Sup guys, need help ASAP. I have a vs2 runs like a dream just replaced water pump,drive belt rad cap etc---all fine. Did spark plugs today ran like a new car but when i left work it was running like a tank or f100. It sounds like its running on 4 cylinders and goes to stall. Please help i have checked leads and plugs all are sparking well. ANY IDEAS??
I've found it a bit hard to make sure the spark plug leads are on the plugs properly and if they ain't then they will cause a miss. They need to be pushed on a few times I reckon. Didn't knock any vacuum hoses off?
Could be plenty of things, Start with fetching the codes out and start from there. Then check your DFI + Coilpack, after that check fuel and so on. Eliminate things one by one. Hope this helps.
