VS power windows problem (shorting out, blowing fuses)
scotam
VS Equipe
I'm after some help with VS equipe.
The power windows have recently started playing up. I have changed both the relay and the 20amp fuse to the power windows, but the fuse blows as soon as I turn the ignition on (before I have touched the power window button).
It has been raining for the past few days, so possibly a switch is getting wet.
Has anyone come across this before and can point me in the right direction???
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Check the conduit where the wires go through into the doors, one may have worn through and shorted the wiring out.
Brett_jjj
Tamworth NSW
vs commodore
The power windows should have a small circuit breaker (as shown in pic) plugged into its fuse holder (fuse 5 under dash) not an actual fuse.
