grafton
- Oct 28, 2012
- 57
- 4
- 8
- Location
- GRAFTON NSW
- 2010 VE II SV6 NITRATE SPORTWAGON
Can anyone tell me if VS brake hoses fit VN. I have had two different answers! YES & NO Thanks
No. Different flare types.
That's interesting, the VN-VS use the same rear caliper, I would have said yes.
I'm not sure whether they fit or not, but maybe the flare at the junction box about the axle housing...
irs or live axle is the only difference i know off when you look on ebay for rear hoses they say fit vb to vs
VS on is DIFFERENT.Best I could find to fit VB-VS was FRONT only sets. Any with rear hoses are specific to for VB to series 1 VN then series 2 VN to VS were different. The sets listed on ebay with rear/rear only to suit VB to VS, in the full desciption says, you must supply vin # or specify your exact model so we can send you the correct set.
I suppose the real answer is to buy the wrong ones then find out the hard way!.......which no one wants to do. Hope this helps any one else changing their hoses.
**** FRONT-VB to VS are the same. REAR-VB to series 1 VN are the same. REAR-Series 2 VN to VS are the same****
