pete30nz
- Mar 21, 2011
- 526
- 96
- 28
- Age
- 43
- Location
- Christchurch, NewZealand
- 1994 Vr berlina 3.8 v6 , 1996 VS executive 3.8 v6
Hi people,
My rear demister switch isn't lighting up,
It could be the led that's gone bung.
I have checked the fuse, it's good.
Also checked the relay and its working.
I've multimetered the rear window on the beep test with the power and earth disconnected, a good continuous beep, hoping this means the rear window heater circuit is all good?
It has power there when I multimeter it, and turn switch on and off it comes on and goes off.
So does the switch orange led have to light up for it to work properly?
I only tested it in the last 20 minutes, haven't had a mist to demist this morning to check if it worked.
Pete
Pete
