VS S2 Instrument cluster into S3
Da_Street_Sleepa
YAY!! BONGOS :P
Toowoomba
VS Commodore Ute
hey guys,
just need to know if its ok to put a series 2 instrument cluster into a series 3,
i recently brought a level 2 cluster with the tacho and i am hoping that there is not gonna be any issues,
i know the plugs line up and everything, but is there any difference in the voltage or anything??
Thanks
turmoil117
Donating Member
Armadale
Vs berlina
Straight swap between all vr and vs clusters
Just make sure its out of a car with the same engine as yours
Da_Street_Sleepa
YAY!! BONGOS :P
Toowoomba
VS Commodore Ute
oh ok, well its out of a series 2 with the 3800 not ecotec, can i run it with a ecotec?
Da_Street_Sleepa
YAY!! BONGOS :P
Toowoomba
VS Commodore Ute
*UPDATE*
took the risk and just put it in, no probs at all, fuel gauge works, temp meter works, trip and total KM's ticks over, Tacho works, Speedo works.
All good, thanks for the help anyways mate, So S2 cluster into S3 (ute that is) no probs solong as the plugs line up and the
plastic circuit boards are similar, then its bound to work
adam10_1990
Brisbane, Queensland
VS Commodore S2 Ute Manual
I was recently thinking about this, as everything except my km counter works (and my fuel needle has epileptic fits)
Demonica
Donating Member
SE Qld
VS clubsport
Good time to upgrade to the level 3 cluster ;)
adam10_1990
So with the level 3 cluster, i know it has all the digital lcds across the bottom, i don't need to wire anything else in to make them work?
Brett_jjj
Tamworth NSW
vs commodore
If a level 1 or 2 cluster was originally fitted, then you will need to do a few wiring modifications to get a level 3 cluster and trip computer to work correctly. Theres some excellent threads about the subject on here, and maybe even
a "how-to" if I remember correctly, just do a search on here for level 3 cluster fitment, or something along those lines.
adam10_1990
I tried, nothing really came up for what i wanted, i now know how to change a bulb though :p
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Search 'Tripin' thread. VR VS L3 upgrade info aplenty :)
