VS s2 slowly losing coolant
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by immortality, Aug 22, 2006.
  1. immortality
    Sth Auck, NZ
    My 97 V6 berlina is slowly loosing coolant, i fill the overflow tank every couple of months etc. i've tightened all my hose connections etc, their isn't any wet spots inside the car either so i don't think it's a leaking heater core. i've checked the plugs afew times and theres no sign of contamination there, got a compression test when i bought it and alls good there, checked and changed the oil and theres no sign of any coolant in there either:bang: it's got me stumped and it's only got 112,000km on the clock. my local wrecker (commodore specialists only)reckons it's a common problem for the ecotec engine to crack heads and slowly use coolant but i find this hard to believe
    any ideas
  2. Tree cutter
    Tree cutter Tree cutter
    Mt Gambier SA
    VX Calais SuperchargedV6
    Check your overflow tank to see if it is cracked. It could be slowly leaking out of there.
  3. immortality
    Sth Auck, NZ
    i'll check that but i don't think thats the prob as i originally noticed there was non in the overflow tank and when i checked the radiator it also needed some coolant after doing a coolant system flush etc. ever since i've always made sure there was coolant in the overflow tank to make sure theres no air getting into the system. imade sure when i filled it to warm the car up and let the thermostat open, keeping the radiator topped up whilst having the bleed screw open and waited until i only got coolant out of it before closing it and the radiator.
    think i might try bleeding the system again??
  4. DeiCide
    DeiCide DeiCide
    VT S2 L67
    My cars been losing coolant, mainly after driving. I turn engine off and slow driping of coolant underneath car near the back of the engine. I have to top it up every 4 or so weeks. so you might wanna check if yours is doing the same.
  5. maginoodle
    maginoodle Member
    vy series2 ss crewman
    mine slowly leaks from the hole in the water pump. i only top up about every 2500 kays. it was hard to track down. you could get your local radiater place to pressure test your cooling system for you
  6. quiksilver1
    quiksilver1 New Member
    vu ss
    if i fill my overflow bottle up my car pisses it out at the top of the radiator,it drops down about 1/2 inch from radiator cap and then stays at this level,i have no over heating problems but effectivley my car doesnt use the overflow bottle as is just sucks it out.has anyone else had this problem?? cheers
  7. Struma
    Struma Urge Surfer
    VS S2 Executive Ute
    Overflowing at radiator cap
    Mine does the same thing - forget about filling it at the overflow, as all that happens is it blows out from under the cap - all over the engine bay.
    But when I check the level under the cap the radiator is (almost) always full.
    Then as soon as I try to lift the level in the overflow tank it will empty out of the cap again once it has been for a run.
    Doesn't overheat nor does there appear to be any head/gasket problems...
  8. immortality
    Sth Auck, NZ
    mine doesn't appear to overheat so i'm not to concerned at the mo, just been tryingto track this one down for about a year now with no success
  9. sixshooter
    sixshooter New Member
    2x VS
    Your radiator cap could be stuffed !!!
    Yes early ecotecs are know to crack heads
  10. quiksilver1
    vu ss
    ive replaced radiator cap,thermostat and replaced coolant with a flush. ive put on 2 different caps still same problem,as me stuffed.might have to pay someone to look at it
  11. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Check under the waterpump for a trace of dried coolant...maybe look from underneath and it will look like a chalky deposit - when the pump fails it usually is difficult to detect until it fails totally. Your mileage is about right for the life of a Ecotec waterpump.
  12. DJ Ice
    DJ Ice Member
    Gold Coast
    MY07 VE Calais V
    I had similar problems after replacing a leaking radiator....turned out to be a corroded heater tap. They are cheap but a bitch to fit :bang:
  13. Raging Bull
    Raging Bull New Member
    VX S Pack L67
    Had this problem on my old Ecotec, valley gasket covers were leaking, a bit of a job cost about $300 to fix. Never had to top up anymore coolant after that.
  14. holden007
    holden007 VRII
    Subaru Liberty
    While the cars running with the radiator cap off (while cold), check to see if the water is bubbling in the neck of the radiator, this could indicate you might have a cracked head.
  15. immortality
    Sth Auck, NZ
    i've replaced the radiator cap and i've had the car running without the radiator cap watching for bubles to indicate a blown headgasket or cracked head but nothing there. i'll have a good look at the water pump this weekend. might have to get it tested properly
  16. holden007
    holden007 VRII
    Subaru Liberty
    immortality
    Have you checked the welsh plugs, they maybe leaking.
  17. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Mine failed at 100K and was hard to detect except for that trace of dried coolant under the waterpump pulley - after a while it started to drop onto the front bit of the sump.
  18. digisol
    digisol New Member
    Central QLD
    Toyota Landcruiser
    Too many different questions, I think one was a welch plug leaking ?
  19. Hytes
    Hytes New Member
    Townsville, North Queensland
    VS Berlina S1
    Hako, this is exactly what is happening to mine at the moment, chalky deposits on top right hand side of sump (looking front on). Tried to see exactly where this is coming from. Have to top radiator up every 3 or so days, would this definately be a water pump problem? Is the water pump hard to replace?
  20. Philthy
    Philthy That dent guy
    3.0R Liberty, XC Falcon
    i had this problem fixed in my vs last week.
    they told me it was leaking from the radiator cap and since they replaced it i havent had any problems
