hako
Donating Member
- Aug 1, 2004
- 8,020
- 96
- 48
- Age
- 80
- Location
- Toowoomba SE QLD
- VS11 BT1 V6
Hytes said:Hako, this is exactly what is happening to mine at the moment, chalky deposits on top right hand side of sump (looking front on). Tried to see exactly where this is coming from. Have to top radiator up every 3 or so days, would this definately be a water pump problem? Is the water pump hard to replace?
Sounds like it for sure (well, 99%). Try to get a small mirror under and around the pump - where the shaft goes into the pump body and underneath where there is a 'weep hole'. Look for the dried deposits.
To change the pump is simple. Loosen the 4 bolts holding W/P pulley to W/P, remove the serpentine belt, undo W/P pulley bolts to enable access to 6 or so bolts hoding W/P to engine block. Remove pump, scrape old gasket away, instal new pump/gasket with no sealant and bolt her up. You may want to replace the coolant at the same time and maybe the thermostat but if the coolant is fairly new just catch it in a bucket and reuse. Same with the thermostat if fairly new although they can last the life of the car. Remember to bleed air from the cooling system via the bleed screw on the thermostat housing. Take your time doing it and you will have no hassles.
Good Luck.
ps....The series 1 VS has a different W/P to the series 2 so make sure they sell you the correct W/P....cost is about $110
