Timbo
- Jun 25, 2018
- 66
- 74
- 18
- Location
- Perth Western Australia
- Vs ute V8 manual & Vl walkinshaw
Custom grind 4903 crow camWhat package?
5208h lifters
4845-16 Valve Springs and retainers to suit.
Yeah I have to get a tune . Bill Lee in Perth will do mine he's a bit of a legend here .That's the same cam as the mace package if I recall.
You have a tuner lined up or did you get the package from them with some lifters?
I'd be keen to know how it goes cause I don't have a tuner for 400kms that can do it.
Ok didn't no this wot is the benefit?Make sure you use a coated oil pump drive gear.
It won’t chew out the cam gear.Ok didn't no this wot is the benefit?
Probably just ground on different lobe centres. I have the same cam, but yet to fit it to an engine. Very keen to hear feedback. Its about as large as you can go lift wise without removing heads for spring seat alterations for double springs etc from memory.Sooo it's crow 4903 = standard 3rd stage ( still fairly small ) and then ground/ modded?
