whiskeytango
- Feb 20, 2019
- 395
- 752
- 93
- Location
- NQLD
- VS SIII 5.0
How'd the tune go?
I 2nd that.How'd the tune go?
How'd the tune go?
I 2nd that.
Also what was specced different on the cam grind?
Tune was completed few weeks ago at Bill Lee was told I had a issue with number 3 cylinder not firing 100% so he serviced the injectors and run a few tests but couldn't work it out . I have since got the car back and have done a compression test and cylinder leakage test and all came up ok. I also pulled number 3 lead off and it drove like a pig then replaced it back and then drove fine . Only thing I can think of is maybe a bit of carbon or something my have got stuck under the valve when he was tuning it but really have no idea because now the car is running awsome. Currently in the process of calling Bill and getting a proper dyno print out as he never did the first time.How'd the tune go?
Awesome! Can you post an idle vid? Keen to see how mine will sound lolTune was completed few weeks ago at Bill Lee was told I had a issue with number 3 cylinder not firing 100% so he serviced the injectors and run a few tests but couldn't work it out . I have since got the car back and have done a compression test and cylinder leakage test and all came up ok. I also pulled number 3 lead off and it drove like a pig then replaced it back and then drove fine . Only thing I can think of is maybe a bit of carbon or something my have got stuck under the valve when he was tuning it but really have no idea because now the car is running awsome. Currently in the process of calling Bill and getting a proper dyno print out as he never did the first time.
When I'm with the car next ill see if I can upload a video..Awesome! Can you post an idle vid? Keen to see how mine will sound lol
Yes I’d like to hear a video of the new cam too. Thanks.Does any one have a picture of the relay diagram of a 1997 VS Utility please? Mine has been changed and not sure what relay fuse goes in starter slot.
