VS slouchy when cold
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by someguy360, May 24, 2011.
  1. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    Hi Guys
    Since winter has hit I have noticed my ecotec has been rather sluggish in the mornings
    on a cold start it will idle fine but just doesn't seem to have much umph when I start driving (throttle almost feels heavier)...after 1-2km it comes right and goes hard.
    My brothers 350,000km L67 Calais doesn't seem to have this problem
    I am running Caltex GTX 20w50 oil if that makes any difference
    Is this normal behavior for an ecotec...it was fine through out summer its just these past couple of weeks
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Possibly your auto transmission needs a service - once the oil warms up the clutches grip better etc. How long since it has been serviced?....should be done about every 3 years or 80K.
  3. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    I agree with hako about the auto trans services,except Id halve that recommended service interval under normal driving conditions.You can also try a different thinner engine oil ,something like penrite HPR 15 ,which is a semi synthetic 15W -60 oil.Its a bit thinner when cold than the normal 20W-50 oil your using so it flows a bit easier when cold.Its fairly cheap too.Ive used this oil for a few years now with no problems,it also stays slightly thicker at high temps for better protection in the heat during the summertime...
