Ive just been checking out the wiring diagram in the workshop manual to see where the speedo etc get their speed signal, and the speedo gets its signal from either the speed sensor on a manual transmission,or from the ECU on an auto trans,via a Violet/white wire,and so does the trip computer, if one is fitted,but I cant for the life of me see where the speed alert module gets its speed signal from,cars that dont have the trip computer fitted,usually have the speed alert fitted instead,so its really got me stuffed.Theres just no wire from the speed alert module to the speed sensor or ECU.Id try to set the speed alert to the digital speedo mode like I mentioned in the above post, and see how much difference there is between the speedo reading and the digital speed reading on the speed alert..if its the same,then the speed alert module might be stuffed.It just pulls out of the dash and unplugs,so they are easy to change over if thats the case.
