VS SS V8. car will not start. stranded
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by sokcin, Dec 20, 2006.
  1. sokcin
    sokcin New Member
    VS SS manual
    Hopefully someone can help me.
    Ignition lights are on and I can hear the fuel pump engage, I turn the key and I hear 1 click and then no response (car does not start).
    I turned the key about 5 times & I saw smoke coming from the starter motor
    area.
    I also checked the oxygen sensor cable and it looked like it was touching the
    exhaust
    I have checked the battery and volts are between 13-16.
    Tried to clutch start with the ignition on to no avail.
    Has anyone else experienced the same type of problem?
  2. VSIIBerlinaL67
    VSIIBerlinaL67 New Member
    VX SS M6
    if there was smoke coming from the starter motor, its prob dead
  3. dmitch
    dmitch DonkeySS
    Perth W.A
    VS SS S2
    prob starter or solenoid... have u checked ur error codes...
  4. jc58nc
    jc58nc Guest
    Forget error codes! If there is smoke you have a loose or bad battery connection at the starter motor or the starter motor is dead.
    A loose or bad battery connection generates heat, and the heat causes smoke.
    Be careful it can be hot enough to burn your fingers.
