VS SS Wont Start
ryan7911
VS SS
So I drove to the gym no problems, went out jumped in turned the key and nothing ( has done this before, I think the key is getting rather flat usually I just take it out turn the key over and put it back in and its fine) waited a minute did it again and its now cranking but wont fire.
The fuel pump is priming, any ideas on what the problem could be..??
BlackVXGTS
Melbourne, SE
1. Immobiliser
2. Ignition module
3. Ignition coil
4. Hall effect sensor in the distributor
Your first step should check if any trouble codes have been stored.
ryan7911
VS SS
Ended up having to get it towed home, will check the codes in the morning and see how we go, appreciate the reply...
ryan7911
VS SS
Ended up getting code 12 and 31, would it still turn over but just not fire if the theft deterrent signal is missing?
BlackVXGTS
Melbourne, SE
This section from the Holden VS service CD may help. In short, yes you can have a DTC31 and still have the engine cranking:
zacogan
zacisback
Kadina, South Australia
vx acclaim, vt ss
my ss just did the same thing today. ordering in a new ignition module and see if that does the trick
