VS Statesman 5.0 won't start..or anything!
miker75
VS Statesman SIII 5.0 V8
Hi,
I was in a parking lot and was about to leave and my 5.0 started spluttering and misfiring, then it died... so I thought "Ok..I'll just restart it"..
Not that easy I'm afraid...
You can hear the relay's clicking, but nothing... no starter motor..nothing..
But that's not the worst of it..
The central locking won't work either.. neither will the immobilizer (no red light on dash)... So I'm thinking the car is pretty much brain dead..
ECU?
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Clean the battery terminals would be the first thing I would do.
miker75
Sorry I should have also said, accessories (eg. cd player etc.) and all lights inside work, dashboard electronics work, they do not dim when the ignition is turned on (Although the CD player "turns off", that's normal for starting).
Also tried removing the battery terminals and leaving for a couple of minutes and then replacing, same thing..
keza87
JCCC NSW Member
34
VX/VY/VZ Wagon LS1
I would say check the fuses. In my VR if I pull out my fuel pump fuse the immobiliser stops working and the central locking stops as well. Really weird but maybe check that. They are the fuses under the bonnet
88GreenVN
Next Exit Left
Surprise, Arizona
Starter motor cable connected? - maybe give the starter motor a gental tap
Could be the ECU - but sounds like the security is killing things
88GreenVN
Next Exit Left
Surprise, Arizona
Does the fuel pump fire up when you turn the ignision on?
miker75
Fuel pump??? interesting....
I would have to say.. no it doesn't...
I was trying to listen to it when I turned the ignition on.. but I don't recall hearing it running..
Didn't check the fuel pump fuse... will check that and get back :)
88GreenVN
Next Exit Left
Surprise, Arizona
If the imobaliser is kuput - it will possibly cut the fuel, ignision and central locking too.
Don't know if you can by-pass this like the VN's by unplugging the unit under the dash pad..
miker75
Where would that be located?? I just assumed the ECU did everything pretty much..
