VS statesman antenna
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by wolftain, Apr 17, 2011.
  1. wolftain
    wolftain New Member
    VS Statesman
    So i had a run in with a gala which did a few bad things to my car, ie broken windscreen and lights which have been fixed but my antenna snapped off,
    currently just running a spare jammed in the hole which seems to work, however i would like to fix it.
    whats the go with new antennas?
  2. Asmodai78
    Asmodai78 Active Member
    VE Calais V Sportwagon
    try a wreckers or go and get an after market replacment
  3. VS_Pete
  4. vscaprice98
    vscaprice98 New Member
    brisbane
    vs caprice
    holden aeriel are expensive have a look first if u can put a cord replacement in first there much cheaper option if ur power aerial still working bud
  5. Cpt Awesome
    Cpt Awesome Member
    perth wa
    04 S II HBD VY SS , 04 VY S II Executive
    i just replaced mine, and now have to do it again after a high speed bush bashing event... Antenna is 60-70 bux. you can get it from covrntreys, auto one, super cheap their all the same. to acess it you need to take the guard off from inside the wheel tub. only need to unscrew the trailing edge of the wheel arch, pull the piece of plastic out over the lip of the arch and you can see the electric antenna module thingy. then its all pretty self explainitary from there (undo whatevers holding it on then do the reverse to remount it) dont for get to reattach power lol
  6. justbad4you
    justbad4you IF YOR NOT A HOLDEN
    MELBOURNE S/E BAYSIDE
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    GET A STEM KIT AND REPLACE the stem with the new 1.....way cheaper
  7. fallen1
    fallen1 New Member
    1999 Holden VS Statesman
    just to o over that guys point again.. most mechanics will try to stooge you by replacing the whole system (motor Ariel and everything else).. but inmost cases the motor is still perfect and all u need is a new stem/sleeve... sooo i reckon the stem kit is the way to go aswel =D
  8. 96calais
    96calais New Member
    maroochydore
    96 vs calais series 1
    my motor drives up and down correctly but the mast is snapped off inside, any way of getting the mast and cord out??? good luck fixing yours brother.
