Vs statesman diff to vs ss??
logan binns
35
nz taupo
Holden Commodore VS Statesman L67
Hi, I have what I'm told is a vs ss lsd diff IRS that I'm swapping for my v6 single pegger in the statesman but 1 problem 1 flange vs ss has a rubber with 3 bolts and mine has 6 bolts for the tail shalfs. How do I swap the 2 over? The top 2 are supposedly the vs ss the bottom 2 are the vs statto v6 currently starting the turbo process. Thanks for the help.
_R_J_K_
Zenki S14
The new diff is definitely not from any VS. That's from something VT2 onwards. You can swap the flange to make it fit.
Are the two housings different or is one of them an LSD (look for a tag that specifically mentions 'LSD')? If not it, might be pointless swapping it.
logan binns
35
nz taupo
This is inside the vs ss diff
logan binns
35
nz taupo
Are the two housings different or is one of them an LSD? If not it, might be pointless swapping it.
Yea I thought it wasnt got ripped.
Yea I thought it wasnt vs got ripped again I will need to swap flange and back cover as it didn't come with the abs sensor brackets. 1the new 1 is lsd high performance my vs statto is high performance but nt lsd. Diff housings look very similar except for the place ment of I'd tags [filler holes] number on crown wheel is p5a186 same number on pinion
logan binns
35
nz taupo
Can any 1 advise how to change flanges? Ps thanks r j k for the confirmation
