Vs statesman twin cat exhaust
Fatgmh
40
Vs statesman
Hi does anyone know if the V8 and L67 twin cat system is identical? Apart from manifold of course.
Looking for an exhaust shop to build complete complete system from extractors back. Also will existing cats be sufficient?
ephect
Donating Member
VS Acclaim V6
If they're both from a stato, the catback should be the same.
If the shop is going to build it from scratch it will be fine. Twin cart will be fine
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
No, they aren't the same on a VS. L67 still only has a single cat. Manta do a twin cat V8 system, you would need to have the cat pipes fabricated from the headers to the front muffler section then any twin cat VS Statesman system will fit it. VS are weird because the twin cats are offset, one pipe is longer than the other.
Fatgmh
40
Vs statesman
my VS L67 definitely has a factory twin cat system. Might have to speak to Manta. Don't mind dropping $1000 if it bolts straight up.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Odd...yours a series 3?
