vs sump gasket
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, May 23, 2012.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    hi, i know the way to change the sump gasket on a vs is to either drop the k frame or remove engin, has anyone done it without removing teh k frame or engine?
    also why is it on teh series 3 engins you dont have to do either? what is the difference?
    i replaced teh sump gasket in me vn years ago, but i had to remove k frame as i was redoing all teh front end anyway and made up a support to hold the engin etc....worked dam good but very time consuming and needed a wheel alighment anyway
  2. two-bit
    two-bit old enough to mang better
    VS S series II
    if you have an engine crane just pop the engine of the mounts and can try it that way. i did it like that on my vr it worked but was a pita to do not much room to get a spanner in and it damaged the rear main seal doing it that way
  3. UW1SH
    UW1SH New Member
    Iv done a few sump gaskets on vp,vr,vs. I have always pulled the engine out and did the rear seal at the same time and cleaned all the oil and stuff off the engine etc. Not hard to do if you have the time and patience and right tools and of course know what your doing etc..
  4. VR38
    VR38 Well-Known Member
    VB SL/E
    I don't know if it is any different on a 6 or an 8 but I can't even get a socket on most of mine in the car to nip them up, let alone remove the bolts.
    You must have more patients than me.
