Vs thermo fan removal?
mwhit43
27
Vs excuetive
I've searched this forum for the removal of the vs thermo fans. Can somebody please help me? I'm 15 and I need to replace a vs radiator and need the thermo fans out! Please help me!! If you can, can you post up some pictures to show me what I'm looking for?
Thanks in advanced
Disturbed_vegeta
I'd Prefer To ROAR!
34
Burpengary
Www.myspace.com
VR Hsv Senator, VX SS, VZ SS Ute 6L, K9 GSXR1000
i havent owned a ecotec for a few years but from memory, But all you have to do is get the radiator out. First remove the coolant hoses (2 big hoses) and the trans lines (if a auto) then remove the clips that hold the radiator in(use pliers or a flat blade if necessary) then unclip the power steering res(jsut lifts out) then theres a plug under that mount, unclip that. then pull the whole thing out...then 4 10mm bolts the fan should come off..
Hope it helps.
stuartl1989
Its not your's
Caboolture
96 VS
removing the thermo fan is pretty damn easy! its just a bolt in each corner and a plug (or 2) on drivers side and then wiggle wiggle........
