vs throttle body size
VRV666
VR 3.8 exec, big pajero, 5speed vn v6 play car
Just wondering what size the vs v6 throttle bodys are? I know that the vn v6 to vr v6 are 60mm but I heard that the vs v6 is 65mm like the v8s? Im sure this isnt true but was wondering anyway.
VRV666
yep, thats what I thought, cheers.
sircruisealotVS
South Brisbane
VZ LS1 Calais
hmm, i think you'll find the ecotec t/b IS 65mm.
holden007
VRII
Subaru Liberty
I think the VS are 64mm TB, correct me if i'm wrong.
AirStrike
37
91' VN SS
Correct. The Ecotech uses a 64mm throttle and the 5.0lt a 65mm.
AirStrike :air:
VRV666
o.k then, the next question would be, does the ecotech throttle body go onto vn-vr? I dont see why it wouldnt.
holden007
VRII
Subaru Liberty
Nope. the VS is different to VN-VR. Only the VS V8 is the same as VN-VR V6 and V8 Commodores.
Kevin Hay
Benalla Victoria
vr Calais
Hi guys, I'm new to this site and not sure what I'm doing here lol, I currently own a vr Calais, and I want to put a bigger throttle body on her but what I want to know is what size would be the most benifet from?? its not chipped just a one owner Calais with only 140,000 kms and very clean I basically want to beef the motor uo abit..!!! with a set of exstractors. Sports exsaughst, and as I said bigger throttle body and a chip but the chip will come after the wheels......... So any help,, advice would be great...... Cheers guy's :)
_R_J_K_
Zenki S14
No gains to be had from changing the throttle body unless you have heads done, a cam, or forced induction. On top of that, if you change it without a tune it runs weird (essentially more air for less throttle/fuel, so the AFRs are all out of whack).
Don't waste your time with ebay chips either. The1, Delcowizzid, or Mace can sort you out.
