vs transmission 3-2 hard kickdown problem
wiganmike
37
1995 vs executive
I have a 1995 vs executive v6 which is having a problem with downshifting from 3rd to 2nd.
If I accelerate and it has to shift to second there is a small delay and then it bangs into gear quite hard. Could this be the 3-2 shift solenoid? I have never worked on auto's before so any help would be much appreciated.
wiganmike
37
1995 vs executive
No transmission light on, so will it have a fault code?
The car changes up fine, it even kicks down from 4th-3rd and 2nd-1st fine.
oil level is good.
Is this not a common problem?
wiganmike
37
1995 vs executive
just checked codes and got a 12. so everything fine there
VZ57SSZ
Central Coast
MY16 VF Series II SSV
is there a delay from park or reverse into drive?
wiganmike
37
1995 vs executive
No delay. Everything else is just as it should be apart from the 3rd-2nd kickdown. If I am being really picky it makes a slight transmission noise under hard acceleration in 1st and second also.
wiganmike
37
1995 vs executive
so I guess that nobody knows. Am I really the only one who has had this problem?
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
So did you replace the 3-2 sol yet?
1st gear - Sol 1-2 is on Sol 2-3 is off
2nd gear - Sol 1-2 is off Sol 2-3 is off
3rd gear - Sol 1-2 is off Sol 2-3 is on
4th gear - Sol 1-2 is on Sol 2-3 is on
VR_Acclaim
Banned
Vr acclaim
I had this problem and it got worse the sol where fine, get a service and they'll tell u whats wrong, mine was the bands, I've had mine adjusted bit my box just gave way so yeah what collies ur oil aid it's black ur clutch packs are rooted
wiganmike
37
1995 vs executive
Not yet. I was waiting to see if anyone had the problem and knew for definate what it could be. Thanks for that info its very helpful, making me think even more that 2-3 is sticking on. Would you have any idea if mine is the grey or white plug 3-2 solenoid?
