Vs Ute, cranks but won’t spark
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by F’ckedVSute, Dec 22, 2019.
  1. F’ckedVSute
    F’ckedVSute New Member
    South Australia
    VS Ute s3
    Gidday everyone.
    Need help, I’ve picked up a s3 vs Ute, it cranks but won’t spark. I knew it didn’t start when I got it. I’ve swapped all the usual parts out with another vs to check them:
    crank angle sensor,
    dfi/coil packs,
    Plugs,
    Leads,
    Cam sensor,
    Computer,
    Bcm,
    I’ve tested the wiring loom with a test light to check that the signal gets between cas, dfi and computer.
    The fuel pump works,
    I’ve done Injectors, and fuel filter is fine.
    Battery is new.
    So just wondering if anyone can think of anything i would appreciate any help I can get.
    Cheers guys
    *edit*
    Had a couple hot days around 45 degrees and the Ute decided to spark for a bit, it would fire and run rough for a second then die again. I though it was just stale fuel stopping it then, but by the time I drained and replaced the fuel a few days later, the weather had cooled down and it has lost spark again, so that’s got me even more lost
  2. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    Username checks out
    I would recommend doing some fault finding. Go back to the basics and check if you do have spark first. Pull off a lead and connect to a spare sparkplug and rest it on engine for earth and get someone to crank it.
    Also have you checked for any error codes ?
    Fu Manchu and F’ckedVSute like this.
  3. F’ckedVSute
    South Australia
    VS Ute s3
  4. Utel67
    Utel67 Active Member
    Tasmania
    Vs s3 ute
  5. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
  6. F’ckedVSute
    South Australia
    VS Ute s3
    cheers, I’ll give it a try
    Thank you, that’ll make it much easier
  7. F’ckedVSute
    South Australia
    VS Ute s3
    So I have fault codes 12 and
    so I have codes 12 and 73, so both system fine, and pressure control solenoid in the trans, which shouldn’t stop it starting should it ?
  8. Utel67
    Tasmania
    Vs s3 ute
    F’ckedVSute likes this.
  9. F’ckedVSute
    South Australia
    VS Ute s3
  10. shane_3800
    shane_3800 Active Member
    places
    vr commo
    Swapping the BCM makes this whole exercise pointless.
    You have a mess atm and I would charge extra to fix it. Don't take this the wrong way but it's very hard to diagnose over the net because you've tampered with so many factors. If you fix it Great! but if you've ever seen the pic with the different rates for customers that watch you and try and help you, well the highest increase on the meme image is the person the trys to fix it them self and resorts to the mechanic.
    It's actually an insult as you think we are not worthy and rip offs then you tow your **** box in..... We dont like that.... just a hint.
  11. Trevor loves holden.
    vs commodore
    Was the bcm a match with your number you cant just throw any in, his a list from doctor Bob.
    VS UTE U 92049148 B 92055494
    VS LOW L 92049150 B 92055494
    VS MID M 92049146 C 92056492
    VS LUX X 92049147 F 92056493
    VS HIGH H 92049149 D 92055379
    VS EXP E 92054339 E 92054339
    VS ALM MID - KIT A M41321 A M41321
    Doctor Bob, Apr 13, 2008
  12. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    You are using the matching keyhead with the replacement BCM ?
  13. F’ckedVSute
    South Australia
    VS Ute s3
    I appreciate where you’re coming from and I completely understand, so thank you for the hint.
    If it makes it any better at all, the original bcm and computer is all back in the car. I had simply been advised by a mechanic mate to try it. As for the rest of my tampering I have only really swapped parts around with my other vs to see if that one will run on them.
    Hopefully I haven’t f’cked it
  14. F’ckedVSute
    South Australia
    VS Ute s3
    I was, yes
    But I am now given to understand that that wasn’t going to work, due to the bcms in my utes being slightly different
  15. F’ckedVSute
    South Australia
    VS Ute s3
    Ah right, well that changes things a bit.
    I have the original one back in now anyway, but yeah they were different, my other Ute was the 92049148 Ute one, this one is a Low 92056494.
    The bcm works fine with the key’s remote to turn off the security to let it crank.
    Can you tell me if it will stop it firing though, even if it lets it crank?
  16. Utel67
    Tasmania
    Vs s3 ute
    The other owner probably swap pcm and bcm around also which is why it's not starting, get a memcal with vats removed.
  17. Trevor loves holden.
    vs commodore
    Test the DFI plug with the site I posted if you go down the page you will see all the ways to test the harness, pulse, 12v, cas, once you work out which wire isn't giving you a signal trace it back or replace it, also the harness pins could be bent or not making contact with the DFI socket, Also test your injector wires with a test light with ignition on it should glow if 12v is present, one of the 2 should glow..
  18. Trevor loves holden.
    vs commodore
    If the wrong bcm is used from the original owner well the only way to know which one is correct is ask Holden by suppling them with the vin number but they probably charge you.
  19. Trevor loves holden.
    vs commodore
  20. F’ckedVSute
    South Australia
    VS Ute s3
    Thank you, I have tried some of that, but I’ll give the rest a try as well.
    It’s very much appreciated
