VS Ute Fuel Sender Unit
Matt Harper
VR Ute
Hi All, Just having a quick search and not having a lot of luck. Does anyone have a lead on a new sender unit for a VS ute? What are my chances? Or do I start looking for someone wrecking? Would appreciate any leads.
Matt
stick3
newcastle nsw
vz sedan vs ute gsx1400
Matt
mate only second hand at the moment until some body starts to make them like rare spares
losh1971
North Tas
VE Series I SS Ute
Yep, and make sure it suits a VS ute as VR, won't work. Neither will VS sedan or wagon.
Matt Harper
VR Ute
Ah copy that, thought it might be the case looking online, cheers for that
Mansfield farmer
Mansfield
VS commodore ute
Sorry to butt in - but - does the VT ute sender work? or is the VS unit unique ?? I'm having the same problem - cant find one for the VS ute !!
losh1971
North Tas
VE Series I SS Ute
Needs to be VS ute.
Fachoo
murrayee bridgee
calais 2
VT is totally different sender to VS one.
You can fit a VT sender unit on top of tank but it takes a lot of modification/cutting/welding along with changing lines and different fittings.
07GTS
Australia
VEGTS BUILT BLOWN E85
VT sender also works backwards and slightly less range ohms reading then the VS fuel gauge needs to work accurately
jeepster
WA
VSII Ute
What makes you say only VS ?
You would think VR utes are basically the same model, obviously wagon/sedan are different as in shape of tank and sender.
IIRC, the VR and VS tanks have different vapour separators, and the return line plumbling is different; so not swappable.
