vs ute hazard light problem
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by dave-509, Jan 25, 2012.
  1. dave-509
    dave-509 New Member
    lismore
    vs ute s2 5 speed manual
    Hi guys
    I have a vs commodore ute that i recently had the air-conditioning tested and re-gassed and since then the hazard lights seem to come on when
    they feel like it ... i've replaced the body control module thinking a fault may have occurred within, but i've still got the problem
    i have also replaced the flasher relay in hope that may have been the problem, and the hazard switch itself seems to be ok as well
    can anyone help me with this issue ???? it would be much appreciated thanks
  2. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    the switch may be ok but have you checked the wiring harness for damage?
  3. dave-509
    dave-509 New Member
    lismore
    not to much extent really just behind it and its connection, should i check it further ?
  4. aussie4life11
    Western Australia
    maybe. sounds like it could be a short somewhere along the line. could just be coincidence that it started after the regas
  5. dave-509
    dave-509 New Member
    lismore
    thanx:) i will have a closer look at the harness tomorrow, just hope i find something and its as simple as a short out.
  6. aussie4life11
    Western Australia
    yea. the switch could look ok but be damaged internally. try it with another switch
  7. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    or as simple as replacing the switch :)
  8. dave-509
    dave-509 New Member
    lismore
    i have replaced it b4 with similar problems but this time... when they come on the interval they come on for changes as if the relay was sticking on, but
    the fact they come on without the switch being pressed, well yeah led me to check the switch internally and replace the relay but i still have the problem, it just
    all seems odd. i will replace it tomorrow though if i can't find any shorts in the harness
  9. James39
    Newcastle NSW
    Well the indicator stalk is part of that wiring so the fault could be coming from that side of things.
