Vs ute instrument cluster swap?
Lukeyd
37
Vs
Hi all, my old man has a vs Olympic edition ute the odometer stopped working so he just brought another full instrument cluster from the wreckers. He has fitted it and everything works except the cruse control now. The light comes on the dash but it won't set the cruise. Has anyone delt or herd of a issue like this before??
Thanks Luke.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
Honestly why would you go down that path when you can simply replace your "Sun gear set" in the Speedometer and retain the original cluster and accurate Odometer ???
Lukeyd
37
Vs
Thanks mate. I wish he did but he through away the original cluster so we can't do that now.
vs-lover
wildfiremaint
VR SS , 2007 Subaru LIBERTY Wagon
Ive heard of decluttering.
That must be declustering.:cool:
Maybe the switch at the brake pedal has been disturbed or has gone faulty.
Lukeyd
37
Vs
Lol yes a big mistake. We have checked the switch at the brake pedal and all is fine. We have power a 3 pins on the cruise motor under the bonnet with ignition on and cruse turned on.
It's there may have been something in the other dash that made the cruise lock on but they all look exactly the same.
Dj1crook
1994 VR Commodore/Lexcen, 1992 Holden Nova Hatch
check the brake lights to see if any are blown
losh1971
North Tas
VE Series I SS Ute
There are two pedal switches for the cruise the other be could be faulty, as is quite common.
