hey guys does anybody know where i can get a lsd diff for my vs ute around brisbane to sunny coast, have tried all wreckers but noone has one! its coming to the stage where im gonna have to lock it up which i dont want to do, or if not what changes have to be done to put a sedan LSD in there? if its possible
Probably a fair bit to get a sedan one in there, not that I'm an expert Is a wagon the same as the ute? Could try them too Otherwise ebay but not sure how many you'd find for the Ute 1999 V6 Holden Commodore Series 3 VS Ute LSD Diff | eBay That is pretty reasonable although a shock mount is stuffed Also I did some reading and by the look of it Ute and Wagon non-IRS diffs are interchageable but don't quote me on that
Yes wagon and ute are same, and that's in nsw would cost to much for postage lol just gonna get a mini spool I reckon
I wouldn't know (referring to postage maybe 50 bucks?), but a mini spool is probably the cheapest and easiest yet not so legal way
If you cant find a lsd diff for your ute you could always just by a lsd from a sedan and dump the lsd unit into you diff housing so long as there both BW78's.
good stuff bro, atleast you know for next time that you can take the lsd unit itself and throw it in a wagon ute or sedan.
Im using a diff from a wagon in my ute. Only difference is the wagon diff dosent have the bumpstops welded onto the diff. It makes the ride alot smoother tho if yours sits as low as mine
compliance plate code is GU8 for LSD , and GU4 for open centre diff.. Mounting points ( shocks ) , Wagon and ute are the same , sedan is different.
