Wozza
- Dec 13, 2011
- 1,925
- 317
- 83
- Location
- Adelaide
- VR_GS commodore
neg battery term off, remove the plugs on the tps and IAS inspect for damage and spray with some contact cleaner...check there is no vacuum hose in that area that is perished and moving with the harness....make sure harness is supported and has sufficient slack in it, fix the earth wire with a more robust one...check engine mounts are fine (maybe pulling on harness when motor moves)As you had to mucked around with the T/B area when doing inlet it may just be a loose connection and not related to the shudder...Also as you have digested coolant through the motor the O2 sensors maybe stuffed and the plugs may need a good clean/going over....
