Anson38
- Jun 11, 2022
- 13
- 3
- 3
- Age
- 40
- Location
- Chinchilla
- Vs commodore ute
Have to check on them other things you said like Pulse dampener and standard regulator
No need to upgrade. I was just trying to get an idea of specifics on the setup.They are standard the Pulse dampener and standard regulator should I upgrade the fuel pump and Pulse dampener and standard regulator
No use buying an OBD II scan tool for a VS, it won't work.Ok I'll get new throttle body sensor , map sensor , O2 sensor , and a ob2 scan tool and let you know how I go
That means reg is buggered and leaking internally to intake manifold.Yeah it is wet on that vaccum regulator and pulled plugs don't seem to be fuel in bores ,
sounds like the intank return line to the venturi jet on swirl pot is leaking/broken and not filling the swirl pot properly so your pump is sucking fuel/air and system is not up to required fuel pressure when the pump primes up.Hi to all , main problem is each time the tank drops below quarter of tank , I start it up and sounds like back firing and pinging then takes of and goes hard ,
