Vs ute wont start but will crank like it wants to.
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by gippa, May 6, 2019.
  1. gippa
    gippa New Member
    ballarat
    vs ute and vt commodore
    Hey i not long ago brought a 96 vs ute and found out it wont start i have checked the fuel pump,coil packs and DFI and also bcm have also changed the fuel filter and crank angle sensor and the starter motor am gonna check the PCM/ECU and the spark leads and plugs have also noticed its been on gas but the last owner took out the gas system just seeing if anyone has any ideas on what it could be or what to check next also!
    Be much Appriciated!
  2. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    losh1971 likes this.
  3. gippa
    gippa New Member
    ballarat
    Checked for codes no codes also changed fuel rail pressure regulator and leads and plugs still no go
