My VS V6 makes a clicking sound when turning left. Not 100% what i need to replace.
VS_WPN New Member Joined Apr 15, 2009 Messages 135 Reaction score 0 Points 0 Location VIC Members Ride N/A Aug 31, 2009 #1 My VS V6 makes a clicking sound when turning left. Not 100% what i need to replace.
i'm timmy New Member Joined Aug 31, 2009 Messages 51 Reaction score 0 Points 0 Location northern burbs Members Ride vn calais Aug 31, 2009 #2 bearing tops! 100% there like $5 from all auto parts places and the sit on top of the strut before it couches the body at the front!
chrisdoesitbetter | → ³8°º™ ← | Joined May 3, 2009 Messages 298 Reaction score 2 Points 0 Location Adelaide Members Ride VR 3.8L Aug 31, 2009 #3 also if that doesnt fix it, try checking your diff... sometimes the internals of a diff "chatter" when worn
ephect Donating Member Joined Jul 27, 2006 Messages 5,923 Reaction score 15,539 Points 113 Location Melbourne Members Ride VS Acclaim V6 Aug 31, 2009 #4 does it click when braking or hitting bumps or only turning left?
0 08sky_way Member Joined Sep 9, 2008 Messages 104 Reaction score 0 Points 16 Location Kingsley WA Members Ride VR Acclaim Aug 31, 2009 #5 Check to see if any of the rubber bushes at each end of the stabiliser links (attached to the stabiliser bar) are missing.
seraphic06 Woodgrain Nut Joined Sep 30, 2008 Messages 477 Reaction score 1 Points 18 Location Adelaide, SA Members Ride VZ Berlina Wagon, VS Caprice Series II 5.0 Aug 31, 2009 #6 Check your steering rack and tie rod ends. The bushes will probably need replacing as well. Last edited: Aug 31, 2009
C crazy.vr New Member Joined Apr 26, 2009 Messages 93 Reaction score 0 Points 0 Members Ride VR Commodore Aug 31, 2009 #7 Check your tie rod ends. Might have play in the ball joints. To do a quick test, turn the motor off and with the wheels straight ahead on firm ground, move the steering wheel side to side. You shouldn't feel or hear any noise or have much play.
T tt460 New Member Joined Jun 1, 2009 Messages 177 Reaction score 1 Points 0 Location bong from the gong Members Ride VS exec Aug 31, 2009 #8 tie rods here also
VS_WPN New Member Joined Apr 15, 2009 Messages 135 Reaction score 0 Points 0 Location VIC Members Ride N/A Sep 1, 2009 #9 the sound is also coming from the front left. forgot to mention that.
C crazy.vr New Member Joined Apr 26, 2009 Messages 93 Reaction score 0 Points 0 Members Ride VR Commodore Sep 1, 2009 #10 Did you check what has been posted?
