Jackdaniel
- May 28, 2017
- 2
- 0
- 1
- Age
- 29
- Location
- Cowell sa
- Vp exec
So i brought a molested vs ute that i will eventually use for burnout comps if i can get it going
Bit of back ground- the people before me have basically striped the inside dash every thing gone only thing left is wiring pretty well. They also had a vn v8 wiring loom connected with plugs cut and shut etc.
I have - put a vs V6 wiring loom back in with all sensors and plugs good. put new DFI in as there was no spark on 1 & 4 coil (there is now spark on all).
What is happening - it has a fuel pump connected straight to the fuel rail (so not using the one in the tank) there is fuel coming out of the return line. motor will crank over but wont fire but will fire if petrol is squirted into throttle body but then stalls and thermos kick in car is still cold because hasn't run. i have waited up to 5 mins but thermos stay on until turning ignition off and on. at the moment there is no dash cluster hooked up.
I'm leaning towards changing the CAS as that may stop the injectors from opening up???
Any help greatly appreciated, Cheers Guys.
