cb754
Hi all, have just changed the DFI, after changing out the CAS, TPS, coil packs and leads. And is now running on all 6 cylinders, but idle is running about 3000 rpm, (no taco), Where to look next..????
removed the idle sensor, checked all that, took off battery terminal for half hour or more.Cleaned the Idle Adjuster and connection?
Reset ignition?
Thanks Wozza, will give that a goVacuum leak somewhere?
or maybe this?
https://forums.justcommodores.com.au/threads/base-idle.16514/
removing the neg battery term or pcm fuse will reset the pcm/ecu or and Im assuming the ignition
