The Big O
- Apr 14, 2010
- 5
- 6
- 3
- VS Series III Ute V6 Manual
Pulled up in my VS V6 Ecotec (Nov 98 Series 3 Ute) and was idling fine then in a split second started running very rough and could not get off idle. Now it will start no problems everytime and run for 5 seconds and then start running rough and coughing and stall.
If i put aerostart up the aircleaner it will start and run fine and rev and no missing but as soon as i drop the aerostart it start running rough again and stalls.
So far i have done the below.
- Replace Fuel Filter
- Clean MAF sensor
- Clean IAC valve and try another IAC valve
- Try another MAF sensor and Air intake sensor
- Block the brake booster hose
- Check for Vacuum leaks
- On key turned to on i can hear the fuel pump prime
- Swapped fuel pump relays and check fuses
- Bridge the fuel pump relay and pump runs fine
- Do a diagnostic and only get code 12 so no errors
