VS v6 ecu playing funny buggers
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by GTP 85, Feb 15, 2009.
  1. GTP 85
    GTP 85 291 hp @ the wheels
    Murray Bridge S.A
    MY04 WRX, VS SSenator & VS V6 track weapon
    Got some annoying issues that i cannot work out n my VS v6!!!
    i have two trouble codes on my ecu when i checked the other day.
    code 47 (CAS reference signal)
    and 94 which is to do with speed sensor (cause im using auto ecu with a 5 speed) Anyway! the code 47 is the one that i am most concerned with here!
    so what i did was change CAS, disconnected the ecu to reset and off i went. But car was still running weird. So i checked codes again... Same codes!!
    I then replaced the complete DFI and coils, disconnected the ecu to reset, and off i went again! after a drive, checked codes again and the two codes are STILL THERE!?!?!?
    Pulled the battery off for several mins, checked codes BEFORE EVEN STARTING THE CAR and both codes remain. I even tried totally unplugging the ecu again, code checking before starting and the buggers remain! What is going on here????
    Just to note.. the speed sensor code im conscious will always be there, but shouldnt it only come up when the car is started?? this code doesnt bother me tho... doesnt cause me any hassles. Its the code 47 that has me stumped? should be the same deal right... as in should only log in the ecu once the car is started?
    Why wont these codes clear?
    PLEASE HELP IF YOU CAN!!
  2. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
    earthing problem? grounding can cause a lot of pain, I`ve got the same prob at the moment with different codes but it linked to earthing, also check the 2 loom plugs at the ecu, pop open the plugs and make sure the wires are seated properly free from corrosion etc..
    Chirpstr likes this.
  3. GTP 85
    Murray Bridge S.A
    Thanks whiteknight
    does anyone else have any imput, or advice on a fix?
  4. -=ApheX=-
    -=ApheX=- Member
    Ya mums house!!!
    VS 3.8l Exec
    ummm, jjust a thought, with your CAS although you've changed it and there should be no issue's with it, i have a feeling it could be a shagged harmonic balancer, basically if it was damaged in anyway, or if it's just at the point in it's life it could be causing issue's with your CAS, as your CAS is a magnetic device and your harmonic balancer passes through it, it could be that this metal is slightly damaged?
    So next step i'd take is replace the balancer so how you go after that!
    Good luck with it mate!
  5. moff_man
    moff_man operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    to set this code the engine is running (darr) below 1200 rpm and the pcm detects 240 reference pulses (80 crankshaft revs) and no 18x reference signal
    and you will have no high resoluition est (electronic spark timing)
    this is also for a auto ecm so im unshure for a manuel one but should be simmaler
  6. GTP 85
    Murray Bridge S.A
    ok..
    i checked all continuity of circuits PCM to DFI and PCM to CAS and they all seem to be fine.
    I also tried the voltage testing method of checking the circuits (as instructed in the Holden Supplementary service book) and that checks out fine too.
    I'm starting to suspect the PCM playing up or the balancer not being right.
