Vs v6 engine problem
MiggzvsC0MM0D0RE
VS commodore executive
Hey guys
My brother in laws vs has been acting up recently. He went to start it the other day. It turned over and then made a popping sound and stalled. It eventually started but he had to drive like a granny to get it home because of a rough idle. Any ideas would be much appreciated.
Cheers.
darcycammo
Cockatoo Vic
Did have VS Berlina now have VT Berlina
what are the spark plugs like?
MiggzvsC0MM0D0RE
not sure, definitely ask him to check tomorrow.
FstStig
Diagnostician
Central Coast, NSW
2010 VE SV6
Check the spark plugs first for sure, then check the leads.... If they all check out fine next would be Coil packs and DFI Module.
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
do a error code check
Hey guys
Cheers.
MiggzvsC0MM0D0RE
Did a check said the 13 for the o2 sensor, you guys reckon that could've caused it to do that?
MiggzvsC0MM0D0RE
Booked into the mechanic for tomorrow, guess we'll see.
Brett_jjj
Tamworth NSW
vs commodore
Error code 13 is the right hand oxygen sensor-No signal.This wont cause the car to stop or play up or make noises etc.The 02 sensors are not even used by the engine management system when the engine is cold.Id still replace both 02 sensors anyway once you get this other problem fixed.A crook 02 sensor will make it bad on fuel,thats about it.Before taking it to a mechanics,Id be checking the spark plugs, the plug leads ,and the 3 ignition coils.These things are easily checked,and one of them is usually the main cause of a misfire or crook running.If the plugs and leads are old its probably worth replacing them first anyway.
MiggzvsC0MM0D0RE
thanks guys.
MiggzvsC0MM0D0RE
Turns Out it was the the vacuum hose disconnected. all good, cost nothing to get fix.
