Vs v6 gearbox problems
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Monxticy, May 26, 2011.
  1. Monxticy
    Monxticy New Member
    Rockhampton
    Vs v6 ute
    If when I start car the engine management light comes on when I try taking off in drive it is real sluggish so I hav to start in first n go thru gears.but sometimes when I start it the engine management light doesnt come on the gearbox seems fine! I hav changed n checked oil. But I hav no idea where to look now! Can anybody offer any help or ideas pls!!
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Welcome to the forum.
    When the engine management light comes, it means there may be a serious engine/transmission problem. The ECU then goes into damage control mode and runs the car on what they call "Limp Home Mode" (LHM) which only allows the transmission to operate in 3rd when Drive is selected. Also allows manual selection of gears and reverse. So, the result is a very sluggish engine. When/if the light goes out, things return to normal.
    You can find out exactly why this is happening by doing a fault code test - very simple and all you need is a paperclip. At a guess I'd say your problem will be a faulty solenoid in the trans - code 82 or similar. Anyway, here is the link on how to do the test. http://forums.justcommodores.com.au...22307-checking-error-codes-vr-vs-revised.html
    Report back with what you find.
    Good Luck.
