Vs v6 issue need help plzz
bt1PWR
VB & VL
Hey all i have a 95 vs v6 that one day driving along the highway randomly lost most of its power and the car wouldnt let me rev over 1500 - 2000 rmp and is a slug now... soo got told the ecu was is limp home mode so seeing as the car had 300 000 kms i decided to replace the motor and gearbox all together after replacing the motor,gearbox,wiring loom and ecu the car still has exactly the same problem????? the new motor was out of a v6 bt1 so new runnig gear and still same problem...
any suggestions to what it could be???
cheersss fellas
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
Sounds like the problem was a collapsed catalytic converter....it blocks the exhaust gases and you will be restricted in revs/power....yours is a classical symptom.
